i use AiO installation. and i can access my pi3 via web.
now i open my andriod phone and use the app, it just keeps tell me invalid ha server
i am very new to this. should be a noob problem but i cant find similar topic.
Is your phone on your WiFi or a cellular connection when it won’t connect?
If on a cellular connection, did you make the necessary changes for remote access?
Having the exact same issue, and I’m on wifi
Can you expand on your issue?
Can you access the Frontend via a wired/wifi computer on your network?
Can you access the front end on your phone when connected to wifi?
Can you access the front end on your phone when on a cellular connection?
For each of the above, what address are you utilizing?
I have the same issue. I have set up duckdns and let’s encrypt. I can connect from an external network from my computer and iphone via “https://xxxxx.duckdns.org:8123”. I see no issue there. This link does not work within my network. Instead I can connect internally from my computer with “https://internal-ip-address:8123”, however when I try to access hassio on my phone from within my network with the internal address, I enter my password as usual, the login screen loads for a while, then spits me right back to the login. I am unable to login. It is odd that I can access hassio from the computer but not the phone. I’m not sure what to make of it
if you use let’s encrypt and have put base_url: https://xxx.duckdns.org in your configuration.yaml some have included the port in base_url and some didn’t.
Mainly HA use 8123. let’s encrypt use 443. So from external you might type https://xxx.duckdns.org:443. from internal you might type https://xxx.duckdns.org:8123
router config external 443 internal 8123 / also internal 8123 external 8123
Whether you access from internal or external network by phone or laptop or pc. put the same as what you put according to base_url in configuration.yaml
Unfortunately my router won’t let me forward 443 > 8123 so I just have 8123 > 8123 and access hassio with :8123 always. Like I said, I can access the site from my phone from both the internal and external network, I just can’t log in… There are no issues with logging in externally and internally from my computer via the same url/ip address. It seems to be something about connecting from the phone. I have tried both the safari and chrome apps.
I use chrome browser to login to my HA.
and I have add in configuration.yaml
frontend:
javascript_version: auto
