Trying to determine whether Browser Mod can send a pop-up image to a device. I have an automation that sends a camera snapshot from a Config subfolder to Android TVs, but would also like to target some Android tablets.
Clearly I had to re-read the docs. I now have this in an automation, popping-up on all Browser Mod-assigned devices, side-by-side 2 cameras for 20 seconds:
service: browser_mod.popup
large: true
auto_close: true
timeout: 20000
content:
type: horizontal-stack
cards:
- show_state: false
show_name: false
camera_view: auto
type: picture-entity
entity: camera.north_driveway
- type: picture-entity
entity: camera.north_landing
show_state: false
show_name: false
camera_view: live
Can’t thank you enough for this. Was able to adjust it for all my needs.
I see three tabs but they are still quite small, how can I enlarge the camera images?
I have already tried: size: normal and wide
Hello @curtis-r,
Yes, Browser Mod can send pop-up images to devices. You can use the browser_mod.popup service to display images on Android TVs and tablets. Here’s a basic example: flvslogin.com
yaml
auto_close: true
timeout: 20000
content:
cards:
entity: camera.your_camera_name
entity: camera.another_camera_name
This will display a pop-up with snapshots from two cameras. Adjust the content and size parameters as needed for your setup.
Best Regards,
Daniel Lopez
Hi Daniel,
I had understood that so far. I have also just found my mistake. I had changed it for further cameras to the type: Grid and then worked with 2 columns, for easier maintenance is partly in the UI and the content as Yaml, I had then forgotten the “size” in the UI ![]()
actions:
- action: browser_mod.popup
metadata: {}
dismissable: true
browser_id:
- 1
- 2
- 3
content:
type: grid
columns: 2
square: false
cards:
- show_state: false
show_name: false
camera_view: wide
entity: camera.doorbell
entity: camera.g5_dome_ultra_high_resolution_channel
show_state: false
show_name: false
camera_view: live
entity: camera.garden_medium_resolution_channel
show_state: false
show_name: false
camera_view: live
title: "Cam:"
mode: single
