teras
(Panayotis)
1
Hello all.
I want to create a button for a custom input_select
entity, which it actually has two states, “locked” and “unlocked”).
Ideally I want this button to change color from off to on, when the entity goes from “unlocked” to “locked”.
Is it possible to do it or should I use a custom button instead?
huu
2
How about a template switch for it
rossk
3
I personally would use a custom button for this as it’s probably way easier and quicker
teras
(Panayotis)
4
I was wishing that this could be done with the default button card.
But custom will do too.
Thank you for your hints!
