bronco
(Rene)
July 17, 2021, 10:28am
1
Hi
Does anyone has experience in Tasmotizing this ZB Bridge?
This is the link to the product on Amazon DE:
https://www.amazon.de/APP-Fernbedienung-Sprachsteuerung-Funktioniert-Verbindung-Smart-Produkten/dp/B094JKVLNR/ref=sr_1_3_sspa?dchild=1&keywords=EACHEN&qid=1626331230&sr=8-3-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyVDlMNlJXMDRZTU5VJmVuY3J5cHRlZElkPUExMDA1NzUwM1I5Q1U3MTAzQ1NLNCZlbmNyeXB0ZWRBZElkPUEwOTgyMjExMUpNVU0yWkFETTUxTSZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
koying
(Chris B)
July 17, 2021, 10:40am
2
Not a specialist, but I don’t think your question make sense.
Tasmota is for ESP-based devices, not hubs.
Actually, there is tasmota for hubs. It doesn’t look like this one is supported, though.
eWelink is an software solution, not a brand (the one you point to seems to be “EACHEN”).
Maybe check
Hi everyone, first post here!
I’ve just found out by mistake this awesome Home Assistant framework and to my surprise I couldn’t find a component that would support Sonoff Basic switches (I don’t have others right now) out of the box.
If you have the time (or need) feel free to give it a try, most of the details are already laid out in the description:
https://github.com/peterbuga/HASS-sonoff-ewelink
Looking forward for some possible feedback.
Update
with awesome support from @forums2012 t…
for eWelink integration
francisp
(Francis)
July 17, 2021, 10:49am
3
It does not look like a Sonoff ZB Bridge, so I don’t know. It is definitively not listed here :
Database of Zigbee devices compatible with ZHA, Tasmota, Zigbee2MQTT, deCONZ, ZiGate and ioBroker
bronco
(Rene)
July 17, 2021, 11:41am
5
The device page says it’s ESP32
nickrout
(Nick Rout)
July 18, 2021, 1:32am
6
I don’t think it is mentioned here, so probably not. Zigbee - Tasmota
Then again this is NOT the tasmota forum
blakadder
(Blakadder)
September 22, 2021, 8:30am
7
Thanks to some great work by a Tasmota community member cronyx it can be: eWeLink Ethernet Zigbee Gateway ZB-GW03-V1.2 Configuration for Tasmota
bronco
(Rene)
September 22, 2021, 9:14am
8
Thanks. In the end I decided to buy a Xiaomi Gateway 3 that’s fully supported by HA and runs very well. Have reach throughout the house.
Hedda
(Hedda)
November 1, 2021, 3:13pm
9
FYI, more discussion and links about hacking this ZB-GW03 (and also it as a rebranded product) here:
https://community.home-assistant.io/t/zb-gw03-ewelink-ethernet-zigbee-gateway-now-hacked-with-tasmota-zbbridge-so-can-be-used-via-mqtt-or-as-a-remote-zigbee-adapter-with-home-assistant-zha/341223
ZB-GW03 eWeLink Ethernet Zigbee Gateway is a spiritual successor of the ITead Sonoff ZBBridge
It features an ESP32 chip and a wired Ethernet port (instead of the older ESP8266/ESP8285 and WiFi).
The Silicon Labs EFR32MG21 based Zigbee SiP radio module it uses is the exact same “SM-011 V1.0” modules and Zigbee firmware by CoolKit-Technologies that ITead Sonoff ZBBridge board uses.
The good news it that Tasmota community member cronyx has now hacked it with Tasmota ZBBridge firmware (using same…
