Two related issues, created automation to turn Tasmota flashed sonoff basic (i can control OK via UI), but can only get it to turn on or off - extract from automation.yaml below
##Automation Test_door_2 open
- alias: 'test door 2 to Tas plug 1 off'
hide_entity: true
- platform: state
entity_id: binary_sensor.Test_door_2
to: 'off'
- service: switch.turn_off
entity_id: switch.Tas_plug_1
##Automation Test_door_2 closed
- alias: 'test door 2 to Tas plug 1 on'
hide_entity: true
- platform: state
to: 'on'
- action:
- service: switch.turn_on
Also, started to get this error on config check “Invalid config for [automation]: [action] is an invalid option for [automation]. Check: automation->action->0->action. (See /config/configuration.yaml, line 26). Please check the docs at https://home-assistant.io/integrations/automation/”
It’s moaning about the automation line.
group: !include groups.yaml
script: !include scripts.yaml
Any ideas welcomed! Thanks.
