Can EspHome devices be reused after HA crash/reinstall
Fist of all im new to this forum, programing, Raspberry pi and so on. So bear with me.
Im running HASS.IO on a Raspberry pi 3b+
And yesterday i wanted to upgrade to the newest version. It´s only a few weeks since last update but i did it anyhow.
After update i wasn’t able to login again bud i did have acces to the files by the Samba add-on. I kind of panicked and tried a reboot… Yes bad idea.
Now nothing Works
I have now made a new installation. The system can find my EspHome devices but i can not open the devices and make changes.
Is there a way to reintegrate my devices so i once again can see them and make changes directly in the GUI ?
Thanks a lot
Anders
BTW. I still have the old “crashed” SD card… maybe there’s a way to grab files/info i need form there?
Did you put your esphome yaml files into the new installation?
no i did not. And i didn’t do that on my first installation either.
I just installed EspHome by the add-on store
hello,
yes, they work, but if you haven’t saved the yaml files you will have to rewrite them :confused:
Damn… Is there no way to retract the YAML file ?
I don’t think so…
It is compiled before sending to the modules…
No snapshot ?
I have the old SD card, but if this contains a snapshot i do not know… My skills are limited :wink:
If you haven’t done Snapshot there won’t be one.
On the other hand (sorry … Deepl traduction … I’m not sure !) in the esphome folder the yaml files will be there
But you must have linux system to read your sdcard …
Thanks.
I now managed to get a linux machine up and running and i´m now trying to se if i can find the esphome folder :smiley:
Problem solved.
Here :wink:
Oups … Cross post !
Now get snapshots set up and copy them off the SD card regularly. Daily at least.
