Is there a way I can create an automation to detect my PC switching on so I can use the action to switch on my room lamp?
You could use a power monitoring plug - power consumption should be low when its off and a lot higher when its on.
If you have the PC on a fixed IP it can be tracked pretty easiliy.
or
Or look into any of the device tracker components, many are router based but server the same function.
