Yes one side comes off easy, in my case it was the bottom side, but I only discovered that after I destroyed the top.
Please note that as of now I’ve been unable to get the sonoff RF bridge working with the custom firmware. Am working with @1technophile to get it going
I don’t know if you ever got the 433toMQTTGateway to work but I’ve been trying to get it working for over a week now and it’s not going well.
I think the problem is my remotes don’t work with the library used by the gateway.
I need a decent remote to operate a ceiling fan with a light but I have no idea really which remotes will work. It’s surprisingly hard and confusing to figure out what you would expect to be such an easy thing. I mean, it’s not like ceiling fans are rare or anything.
I really think I’m moving on from the 433toMQTTGateway to trying the Pilight/RPi-RF setup described by @jeremyowens above.
If that works I guess I’ll have a couple of spare NodeMCU boards to play with on some other project.
yes, i’ve verified from the FCC website they are 433.92mhz, ASK modulated, PCM encoded. As well as it says 433mhz on the back of the remote.
but the remotes don’t have to be for a hunter fan. I just need the remotes to work with either your gateway or some other gateway. I already have the remote codes learned via broadlink and i can control the fans via the broadlink component in HA.
If i can send a signal to HA then i can use HA to control the fans.
If I flash it with another firmware I think it will lose the capability to talk with the remotes. I think it will use RCSwitch as the protocol library and I don’t think that library supports my remotes. At least that is what my research has led me to believe. If you think I’m incorrec t in any of that then feel free to let me know where i’m wrong. Any help would be hugely appreciated!
I have already tried the 433toMQTTGateway which uses RCSwitch and it doesn’t work.
Thank you for the suggestion but I don’t think it will help me.
sonoff rf bridge don’t use rcswitch but a proper microcontroller dedicated to RF firmware (that has not been hacked).
Maybe check if there is compatibility list.
I wasn’t saying that the sonoff used RCSwitch from the factory.
He was saying to load different firmware onto it (tasmota). I was explaining I would not really gain any functionality if I did that over using your gateway.
Now, I may be able to use my remotes with the sonoff factory software but then I think would lose the self comtained functionality that I want from my home automation. I don’t want to have to rely on the cloud.
Unless the factory sonoff doesn’t work that way and I misunderstand the way it works.
But a non-hacked sonoff switch needs the could ewelink app to work. so i assume the bridge would as well.
Bridge with tasmota doesn’t require an Internet connection. It doesn’t use the ewelink app at all. I’ve flashed 3 sonoff device (including the bridge) with tasmota software and I can now delete the ewelink app as they don’t use that anymore.
