Probably due to the DST change, a remote HA setup is not accessible.
Thanks to another system on the remote network, I could make some checks - unfortunately, I did not setup ssh to homeassistant yet:
As I’m having exactly the same symptoms right now and my SSH is not running either, I’m wondering how you solved this problem eventually? Last time I managed to resolve this problem by a HA core restart through SSH.
# A freely chosen name for the connection
Host ha-location
# Host name or IP for the "remote" Home Assistant
HostName ha.example.com
# Public SSH port
# (I use a different public port - my NAT forwards that port to port 22 on HA).
# (the example below is the default though.)
Port 22
User root
# Box - I enable this when I want to connect to the Fiber Network Box UI
# LocalForward 3080 192.168.1.1:80
# HomeAssistant - Method 1 - use the local DNS name
LocalForward 3124 homeassistant.local:8123
# HomeAssistant - Method 2 - use the IP address
LocalForward 3123 192.168.1.75:8123
One can likewise configure access to the observer and other devices on the remote network.
My latest issue was that my network operator is chaning the default configurations from IPV4 to CGNAT IPV6 - my dynamic DNS provider does not allow setting IPV6 addresses and I lost remote access. I requested my operator to return to IPV4 full stack, which restored that.
So that could not be fixed remotely because HA was still up and running, but behind an IPV6 address.
