Can Home Assistant trigger a Reolink recording event?
I installed the Reolink integration and now I’m struggling to figure out how an integration in HA would trigger a recording event in a Reolink camera. The use case is when a sensor goes active, trigger a recording event in a Reolink camera. For example a motion sensor around a corner would go active, trigger an automation, send a notification and start the Reolink camera to record for a set interval. This ensures recording is underway when the motion trigger comes around a corner.
I used to have this functionality with Zoneminder being triggered by a wifi door contact. Every camera near the door contact sensor would start recording.
I’m looking for this too. How to send a trigger to record event based on an external sensor - rather than just relying on the camera ai.
I’ve got the bones of this working by calling the camera action (can use record or snapshot i.e. video or image )
e.g.
action: camera.record
device_id: 5fc996d3f82e571c7d893cfb6cb2d9cd
filename: /media/domevideo.mp4
duration: 15
You need to have the directory set in the configuration.yaml file
In my case I created a media directory under home assistant directory and set this in configuration.yaml
allowlist_external_dirs:
‘/media’
I can now trigger a record to my camera and it is saved there. I can browse to it via the Media → My Media side bar
You can then send the video (via iOS)
**** Note the /local add to the path IS needed
action: notify.mobile_app_james_iphone
message: Mailbox Motion Detected Dome
video: /media/local/domevideo.mp4
I am working on a similar thing, but it seems that when you forced the recording – it interrupts reolinks native recording - and creates a couple second gap that misses the action. Anybody figure out a workaround?
Hi everyone,
I have exactly the same need: trigger a recording on the camera when a sensor is activated.
The workaround records the video inside Home Assistant but I want to record it on the SD card in the Reolink camera like it do when a mouvement is detected.
Do you find how to do this?
Did you find an answer to this? I thought for sure this would be the basic functionality. So I bought a RLC-843WA expecting to be able to connect with home assistant and trigger record and stop events. I’m just not seeing that — which seems like the most obvious use case.
