For years now I’ve keep hearing Node-RED is the ultimate automation tool here and there. I never cared for it because I was using HA itself as a frontend for my then automation controller, about a week ago I moved all devices from my old controller to HA, though; thus I had to start from zero, automation-wise. I got out of the way three that were crucial for things to not fall apart here; it wasn’t hard or anything but it was really tedious jumping in and out several browser windows on different areas of HA to work out ambiguities which were made worse by the lingering MQTT devices on the old controller still appearing on the list duplicating their directly-connected selves.
I think I might benefit from Node-RED, if it’s even what I think it is, but the documentation-tutorial-FAQ remix goes from install [︎ standalone;
︎ as HA add-on], to creating [
︎] and deploying [
︎] first flows and then points to YouTube. [
The guides omit mentioning, though, where are these flow deployed to, specially given no connection to another server has been instructed/acknowledged, appearing more like a code assembler/templating utility than something that can pull and manipulate data/systems. Viewing what I have already done in HA from Node-REDs side would be is an easy way to master the basics (and then some) in one step which would be super helpful since I started running against time the minute I switched over controllers; now with all automation gone.
On the last attempt I gave it (now) I added it as an HA add-on. So I know it must be pre-integrated at least but I still have no idea how, or how to pull an automation from HA so I can take it from there. It can’t be MQTT I just removed it to make the duplicate devices go away. Is it a direct API? If I were to deploy a new Node-RED instance, how would it be set up for HA integration?—or anything else for that matter—how is X set up/integrated with Node-RED?
Anyway, I hope you can clear things out.
If all fails, I can always unplug one USB cable from one system o another in the rack; the old controller. Which continued online for some manual control, but this would be like the 6th or 7th time in the last few years, it’d be nice to finally stay put. :)
