Can HomeKit help me make a web call (custom or IFTTT) with Siri?
I’m a big PiHole fan, but every now and then I want to disable PiHole for a bit so I can access a site that is blocked, usually an advertisement. This turns it off for 120 seconds:
https://pihole.example.com/api.php?disable=120&auth=encryptedhashvalue
And if I want to turn it on before the 2 minutes are up:
https://pihole.example.com/api.php?enable&auth=encryptedhashvalue
I use IFTTT to monitor Google Assistant phrases which then calls the webhook. It looks like
Id like to be able to use Siri to make a similar webhook call. Will home bridge or HomeKit let me do something like this?
So I got this working with HomeKit:
shell_commands.yaml
temporarily_disable_pihole: curl 'http://pi.hole/admin/api.php?disable=120&auth=PWHASH'
scripts.yaml
#script:
  sequence:
    - service: shell_command.temporarily_disable_pihole
    - service: script.turn_off
      entity_id: script.temporarily_disable_pihole
