Tjobbe
(Tjobbe)
1
Is it possible for me to remote-in via a graphical user interface remote desktop connection?
I have installed the SSH add-on.
I am not able to SSH in using the ssh [email protected] command.
I am able to use the built-in terminal window of the add on.
Troon
(Troon)
2
The OS, as far as I am aware, does not have a graphical interface.
Tjobbe
(Tjobbe)
3
Can i SSH in from my mac?
I get this when I try:
> tjobbeandrews@Tjobbes-MBP ~ % ssh [email protected]:8123
> ssh: Could not resolve hostname 192.168.178.117:8123: nodename nor servname provided, or not known
> ssh: connect to host 192.168.178.117 port 22: Connection refused
tom_l
4
Did you turn on the ssh addon?
Also it is not on port 8123. Try port 22.
Tjobbe
(Tjobbe)
5
yes indeed, and I can see it in the ha web interface.
tom_l
6
I just edited my post to add some info about ports.
Tjobbe
(Tjobbe)
7
I can log in to the web interface through a browser using 192.168.178.117:8123 but not :22
I cannot access 192.168.178.117 via ssh using 22 or 8123
tom_l
8
Which ssh addon are you using (there are two)?
The core “Terminal & SSH” addon uses port 22.
The community “SSH & Web Terminal” uses port 2222.
Did you configure it with a password?
Tjobbe
(Tjobbe)
9
I’m using this one:
I don’t recall setting a password for it.
tom_l
10
I can’t load that image. You can drag and drop images into your post directly in the forum (resize them first!).
Anyway, try setting a password for your ssh addon under the configuration tab and then restart the addon.
Tjobbe
(Tjobbe)
11
I have this on the config screen:
tom_l
12
Set a password and restart the addon.
Tjobbe
(Tjobbe)
13
Still not able to login via ssh, getting identical error messages. have restarted my terminal window on my mac and the addon.
edit: I was using the wrong username. I should have been using root!
Troon
(Troon)
14
I don’t run the OS or addons, but that looks suspicious to me.
