I’m not seeing the ZBMINI and have put it in pairing mode by pressing the button for 5 seconds (a few times now). I’ve got a Sonoff Zigbee 3.0 Dongle Plus which has other devices successfully paired, so not sure what I’m doing wrong.
Should I be using Zigbee2MQTT instead?
TIA
Power it off for 10 seconds, or switch the switch 10 times in succession.Or press and hold the button until the LED inside the device flashes.
Thanks for the reply. I’ve tried all of those but still not seeing it. The LED is flashing green.
