Can I "calibrate" a temp sensor?
I put together a temperature probe using this RTD PT100 sensor and a MAX31865 board
I have the code in ESPhome and it is reading the temp, but it is slightly off. I have 3 meat thermometers, I tested them all within 1/10 of a degree in hot water (120 degrees [f]) and cold water (10 degrees [f]). But the ESPhome probe was 7 degrees to low on the hot water and about 3 degrees too low in the cold water. Is there any way to calibrate or adjust the output to correct it?
Nevermind. I got it figured out with the calibrate_linear filter https://esphome.io/components/sensor/index.html#sensor-filters
