I currently have an ESP32 using DHCP to get its IP address and now want to give it a different fixed address in the same subnet.
Is there a way to recompile with the new fixed address and reprogram OTA?
When I try to set the IP address to 192.168.0.221 (was 192.168.0.21), I generate the following log
INFO Reading configuration /config/esphome/temp.yaml…
INFO Detected timezone ‘AEST’ with UTC offset 10 and daylight savings time from 04 October 02:00:00 to 04 April 03:00:00
INFO Generating C++ source…
INFO Compiling app…
INFO Running: platformio run -d /config/esphome/temp
Processing temp (board: d1; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- 1.2.2
| |-- 1.0
|-- 1.0
|-- 1.2
| |-- 1.0
|-- 1.0
Compiling /data/temp/.pioenvs/temp/src/main.cpp.o
Linking /data/temp/.pioenvs/temp/firmware.elf
Retrieving maximum program size /data/temp/.pioenvs/temp/firmware.elf
Checking size /data/temp/.pioenvs/temp/firmware.elf
Building /data/temp/.pioenvs/temp/firmware.bin
DATA: [===== ] 46.2% (used 37888 bytes from 81920 bytes)
PROGRAM: [==== ] 40.1% (used 419044 bytes from 1044464 bytes)
Creating BIN file “/data/temp/.pioenvs/temp/firmware.bin” using “/data/temp/.pioenvs/temp/firmware.elf”
========================= [SUCCESS] Took 34.69 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.0.221
ERROR Connecting to 192.168.0.221:8266 failed: [Errno 113] No route to host
Mike
