Can I change the device class for Frigate person occupany
I’m using Frigate to detect a person on my IP camera. The device class comes into HA as “occupancy”. Is there a way to change the device class to “motion” so that the icon will change when it detects motion?
Yes: https://www.home-assistant.io/docs/configuration/customizing-devices/#manual-customization
homeassistant:
  customize:
    binary_sensor.whatever:
      device_class: motion
    binary_sensor.another_one:
If your sensors have cleverly designed entity ids you can use customize_glob to do this a lot more efficently. e.g.
homeassistant:
  customize_glob:  # customise all frigate binary occupancy sensors
    "binary_sensor.frigate_*_occupancy*":
This would match on things like:
binary_sensor.frigate_lounge_occupancy
binary_sensor.frigate_bedroom_occupancy
binary_sensor.frigate_outside_occupancy_1
binary_sensor.frigate_outside_occupancy_2
The frigate integration already handles changing the icon based on occupancy on or off
Thanks for the replies. I changed the device class to motion but that didn’t solve my issue. I’m trying to change the icon from the “home” home icon to the motion icon that changes based on the entity state motion. It seems that the icon: mdi:home-outline is hard coded into the entity. Is there a way to remove that Icon? I don’t specify the icon in the Frigate code.
garage_nw:
    ffmpeg:
      inputs:
        - path: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
          roles:
            - detect
    detect:
      width: 1920
      height: 1080
    objects:
      track:
        - person
#      filters:
#    motion:
#      mask:
    snapshots:
      enabled: true
      timestamp: false
      bounding_box: true
      retain:
        default: 3
Many of the entities have custom occupancy icons. The person entity doesn’t due to the fact that there are no marching person on / off icons except for the motion one and we didn’t want it to be confused.
