Can I completely remove the sidebar and top bar?
To have something like a Kiosk mode?
Try kiosk-mode which you can install via HACS or manually.
Awesome. Thank you so much!!!
Any other solution? Kiosk-mode seems that it will not survive anymore…
I just saw that the developer archived it, hope home assistant work a core feature to do this.
Try this:
Works great with fully-kiosk.
kiosk-mode doesn’t easy for me and also its archived.
i tested the lovelace-wallpanel. lightly skewed has it suggested above… and it works on my setup after 10min… great
THX, works fine.
kiosk_mode:
  hide_header: true
BUT HOW CAN I GET IT BACK?
Hi guys as you can see, kiosk mode is not being developed anymore.
Have a look at: GitHub - thomasloven/hass-browser_mod: 🔹 A Home Assistant integration to turn your browser into a controllable entity and media player
EDIT: browser_mod has more interesting features, I would advise to just dig into it!
@mattf: can you please mark the answer that solved this for you as the solution?
That way this topic has more value for fellow HA-users who search for the same thing + no time/energy is wasted by others trying to help you.
set it per user
kiosk_mode:
admin_settings:
hide_header: false
hide_sidebar: false
non_admin_settings:
hide_header: true
hide_sidebar: true
ignore_entity_settings: false
