Can I connect Vont smart bulbs?
I have multiple Vont smart bulbs and plugs. The company has gone out of business. The devices still work through the Vont Home app but no longer work via Alexa. Is there a way to use Home Assistant app to control these devices via Alexa? If so, how do I proceed? I am new to this app and never even heard of it until five minutes ago, Thanks in advance for any help.
Hi, I’m running into the same issue and have been looking for ways to use my vont light bulbs again. The only solution I’ve found is to take the bulbs apart and flash the chips with new firmware (Tasmota) which you can then connect to the home assistant. In all transparency I have yet to try it, as it requires a tool I don’t have yet, however, based on this guide, I don’t see a reason why it wouldn’t work. It definitely takes a more advanced skill level though
I’m experiencing the same problem with my Vont devices, which include smart plugs and a smart scale. I found an app called Renpho Health that successfully works with the scale, but I’m still searching for a solution for the plug. If anyone has found a workaround, I would greatly appreciate your help!
