I have a Hyper-V server running with multiple Hyper-V VMs. This server is always turned on. I use USB stick with my RPi HA and I know that I cannot do USB path-through on Hyper-V server.
Are there other kind of ZWave controllers that I can connect to Hyper-V VM? Anyone knows?
Microsoft designed Hyper-V to not share usb hardware devices. I really doubt it would work for a z-wave controller that basically presents itself as a serial device.
That is the main reason I run HA on a Raspberry Pi instead of my son’s Hyper-V server.
@Dario_Musante I dont think that can be done anymore on newer HyperV. I dont have the option for serial socket passthrough with named pipes anymore on 2019 HyperV.
I’m trying to find out a way to run the USB passthrough software in HASS.IO though. There seems to be no way to install anything in the HASS.io supervisor so I might need to reinstall without the supervisor.
Will see how much functionality I need to take over myself and see if I like it.
That also then allows me to install the HyperV drivers in the Debian VM so it reports network IP etc to the HyperV machine.
I’m moving from RPi to proper server simply as I have the resources now, but if it all gets too much I may go back the RPi way but run it in on Pi 4 instead of 3.
You could always install OpenZwave daemon on the host machine and connect to it through Hassio.
It’s the way forward for z-wave in Home Assistant anyway, so it might just be a lot less complicated to maintain going forward.
edit: OpenZwave is no longer the way forward for HA, having moved to Z-waveJs. The same would apply though, as the zwavejs server could be run on the host device and be connected remotely to HomeAssistant.
No, considering I was told you can’t get this to auto start as a service wasn’t a good solution for me. Currently evaluating DDA passthru and third party apps to pass the dongle thru.
