The trick with the dimmer is, you don’t need the SPDT/DPDT switch, you can wire them as SPST and put them all parallel
Which is the same as posted by maxym.
I only did not replace the switches, I just ‘made’ them a pulse switch by placing some foam-rubber in the switch (which is the ‘cheap’ version
