I have some ESP32 based devices (nodemcu) configured as MQTT devices with various functions. These functions can be configured with MQTT messages and states (eg light, temperature, humidity) can be reported.
In HA I can, in mqtt.yaml (or configuration.yaml) define sensors or switches with which I can control the devices. However I need to define a MQTT device for each function of these devices and for all devices separately.
I’d like to define a template-device which produces the various entities of the device. I’ve been reading and experimenting with blueprints, templates and helpers but I get no further and would like to ask if someone could help me further.
The controls I’d like to define are, for instance:
- ssid and wifi-password (text)
- reporting time (seconds)
- sensor light/temp/humidity
- the GPIO pins which are used for the periferals
- etc
I’d be very grateful if someone could help me on the right track. Is it a blueprint, should it be made as a template or should I go another route. If this is going to work I’m also planning to create these sensors/controls for my tasmota devices which work as expected but configuration (using the tasmota web-console) is of course very inconvenient.
The working control I made in mqtt.yaml is:
light:
- unique_id: ESP_01_light_brightness
name: ESP 01 light brightness
state_topic: stat/ESP32_01/POWER
command_topic: cmnd/ESP32_01/POWER
brightness_state_topic: stat/ESP32_01/Dimmer
brightness_command_topic: cmnd/ESP32_01/Dimmer
qos: 0
retain: false
brightness_value_template: "{{ value_json.Dimmer }}"
state_value_template: "{{ value_json.POWER }}"
payload_on: "ON"
payload_off: "OFF"
optimistic: false
switch:
- unique_id: ESP_01 light switch
name: ESP 01 light switch
qos: 0
retain: false
state_on: "on"
state_off: "off"
payload_on: "on"
payload_off: "off"
The experiment in blueprints I gone through, and which does not work, is:
blueprint:
name: BLP - control ESP32 settings
domain: automation
description: Blueprint to make ESP32 controls available as entities in Home Assistant
input:
esp32_id:
description: Select the tasmota device to control
selector:
text:
type: text
bool_light_switch:
description: Light switch
selector:
boolean:
default: true
num_light_brightness:
selector:
number:
min: 0
max: 100
default: 50
mode: single
- platform: state
entity_id: !input bool_light_switch
- platform: state
entity_id: !input num_light_brightness
condition: []
variables:
tr_bool_light_switch_triggered_var: 'cmnd/{{ esp32_id }}/POWER'
tr_num_light_brightness_triggered_var: 'cmnd/{{ esp32_id }}/Dimmer'
- choose:
- conditions:
- condition: trigger
sequence:
- service: mqtt.publish
qos: 0
retain: false
topic: tr_bool_light_switch_triggered_var
payload: "toggle"
- conditions:
sequence:
schema: template
qos: 0
retain: false
topic: tr_num_light_brightness_triggered_var
payload: num_light_brightness
