Before I get too involved with this idea I want to make sure it is possible to do this. I know that triggers are handled a bit differently than other parts of the automations (or I think that’s the case).
What I would like to do for one of my BP is to have a boolean toggle that would allow the user to decide whether to use the feature or not. Can I do something like this:
I would, of course pull the value from the blue print like rotate_enabled: !input rotate_enbled_value but wanted to illustrate by defining it above for clarity.
For the record I did try this with the proof of concept automation but it seems the trigger_variables is not retained on save so I guess it is only available in blueprints?
Trigger variables is a valid key for any automation, blueprint or not.
There is a possibility that enabled: does not accept templates.
in that case it should accept !rotate_enabled!input rotate_enabled there in a blueprint.
But I have a input number as a variable. How can I format that in the trigger? I think I need the leading ‘/’ right? Will it accept a string? I am wanting it to fire every 5 minutes as an example but it is dynamic based on user input.
This is valid BUT it will only fire at whatever the value is after the hour (like 12:19) and not every 19 minutes as I had hoped. Is there any chance I will be able to format the variable to be something like /19 ?
Yeah, the correct format is “/19”, but you would need to use a text input and instruct the user in order to use that as an input for that type of trigger.
Otherwise, I think you would need to use a template trigger.
