now with ESPhome, can i flash tuya devices with ESPhome (Over the Air) ?
digiblurDIY way?
Refael
digiblurDIY way?
Refael
yes, compile the .bin for your device with esphome then copy it to tuya convert and use it as third_party.bin
If you’re going to follow blakadder’s advice, you need to be absolutely certain that the wifi credentials are correct and that the firmware will boot. If either of these things fail, since, presumably, you can’t open the device to flash it over the wire, you’ll have a brick.
