Is there a way to extend the ESP32 Camera Component?
In a nutshell, the ESP32Camera is a C++ class. So, in theory I can create a new ESPHome component, which C++ part can be a class with ESP32Camera as a parent.
But I’m completely struggling with a Python part of a new component. I looked at the BME280, Climate ID component sources and tried to define an init.py file. Unfortunately without any success.
Where am I wrong?
import esphome.codegen as cg
from esphome.components import esp32_camera
#import esphome.config_validation as cv
#from esp32_camera import CONFIG_SCHEMA as CONFIG_SCHEMA_BASE
#from ..esp32_camera.__init__ import to_code as to_code_base, cv, CONFIG_SCHEMA as CONFIG_SCHEMA_BASE
AUTO_LOAD = ["esp32_camera"]
esp32_camera_detector_ns = cg.esphome_ns.namespace("esp32_camera_detector")
DetectorComponent = esp32_camera_detector_ns.class_("ESP32CamDetector", esp32_camera.ESP32Camera)
CONFIG_SCHEMA = esp32_camera.CONFIG_SCHEMA.extend(
esp32_camera.cv.GenerateID(): esp32_camera.cv.declare_id(DetectorComponent),
async def to_code(config):
await esp32_camera.to_code(config)
#pragma once
#ifdef USE_ESP32
#include "esphome/components/esp32_camera/esp32_camera.h"
namespace esphome {
namespace esp32_camera_detector {
class ESP32CamDetector : public esphome::esp32_camera::ESP32Camera {
private:
public:
ESP32CamDetector() : ESP32Camera() {}
} // namespace esp32_camera_detector
} // namespace esphome
#endif // USE_ESP32
