Hello from Slovenia
I tried install Ubuntu on my mini pc HP t530 via USb boot and after 1 minute install …crashed install proces.
Is this related to Home Assistant?
If not, try the Ubuntu forums.
If you’re following the docs on how to install HAOS on a PC, it doesn’t have to be Ubuntu. I used Linux Mint, which has clearer instructions for creating the bootable USB stick.
I installed it on one using Debian. I also did another HAOS on another one. So yes, it’s possible.
As someone who used Ubuntu for years and switched to Proxmox; use Proxmox. Create a VM running HAOS.
I managed to install HAOS on HP T530 - it works
