Thanks to Robert Alexa’s work on the converter and readme over on z2m, I now have a perfectly working thermostat with some basic scheduling included. I tried Schedy but it did mad things with a whole range of entities I hadn’t asked it to (including spooky TV/music/light changes at random times!!) so I just deleted it and went with a more manual set up…
Thought I’d share my thermostat package file and lovelace cards in case anyone has similar case needs something similar:
EDITS: handful of edits to clarify some bits incase anyone comes down wanting to duplicate this in the future.
Config
I use packages, with this in configuration.yaml:
## /config/configuration.yaml
homeassistant:
packages: !include_dir_named packages
and the package:
## /config/packages/house_thermostat.yaml
## Hive Thermostat
# Switch for frontend to toggle heat/off - with both system_mode and heating_setpoint_hold
switch:
switches:
thermostat_mode:
value_template: "{{ is_state('climate.house_thermostat_receiver','heat') }}"
turn_on:
service: mqtt.publish
topic: zigbee2mqtt/house_thermostat_receiver/set
payload: '{ "system_mode":"heat", "temperature_setpoint_hold":"1" }'
turn_off:
payload: '{ "system_mode":"off", "temperature_setpoint_hold":"0" }'
icon_template: >
{% if is_state('climate.house_thermostat_receiver','heat') %}
mdi:fire
{% elif is_state('climate.house_thermostat_receiver','off') %}
mdi:power
{% else %}
mdi:alert
{% endif %}
# Adds a temperature sensor to HA from the thermostat temperature
template:
- sensor:
icon: mdi:thermometer
state: "{{ state_attr('climate.house_thermostat_receiver','local_temperature') }}"
state_class: measurement
unit_of_measurement: °C
device_class: temperature
# Scheduling - input times to change temperature
input_datetime:
thermsched_01:
name: Thermostat Schedule 1
icon: mdi:numeric-1-circle-outline
has_time: true
initial: 06:00:00
thermsched_02:
name: Thermostat Schedule 2
icon: mdi:numeric-2-circle-outline
has_time: true
initial: 09:00:00
thermsched_03:
name: Thermostat Schedule 3
icon: mdi:numeric-3-circle-outline
has_time: true
initial: 16:00:00
thermsched_04:
name: Thermostat Schedule 4
icon: mdi:numeric-4-circle-outline
has_time: true
initial: 21:00:00
# Sheduling - corresponding input temperatures for each input time
input_number:
thermtemp_01:
name: Thermostat Temperature 1
initial: 21
min: 5
max: 32
step: 1
thermtemp_02:
name: Thermostat Temperature 2
initial: 18
min: 5
max: 32
step: 1
thermtemp_03:
name: Thermostat Temperature 3
initial: 21
min: 5
max: 32
step: 1
thermtemp_04:
name: Thermostat Temperature 4
initial: 15
min: 5
max: 32
step: 1
# Automations
automation:
# Scheduling automation - change temp at corresponding time
- id: house_thermostat_schedule
alias: House Thermostat Schedule
description: 'Sets house thermostat temperature based on input_datetimes and input_times'
- platform: time
at: input_datetime.thermsched_01
- platform: time
at: input_datetime.thermsched_02
- platform: time
at: input_datetime.thermsched_03
- platform: time
at: input_datetime.thermsched_04
condition:
- condition: state
entity_id: climate.house_thermostat_receiver
state: heat
- choose:
- conditions:
- condition: trigger
sequence:
- service: mqtt.publish
payload: >-
{"system_mode":"heat","temperature_setpoint_hold":"1","occupied_heating_setpoint":"{{ states('input_number.thermtemp_01') }}"}
- conditions:
sequence:
payload: >-
{"system_mode":"heat","temperature_setpoint_hold":"1","occupied_heating_setpoint":"{{ states('input_number.thermtemp_02') }}"}
- conditions:
sequence:
payload: >-
{"system_mode":"heat","temperature_setpoint_hold":"1","occupied_heating_setpoint":"{{ states('input_number.thermtemp_03') }}"}
- conditions:
sequence:
payload: >-
{"system_mode":"heat","temperature_setpoint_hold":"1","occupied_heating_setpoint":"{{ states('input_number.thermtemp_04') }}"}
default: []
mode: single
# Fix accidental auto mode selection from the SLT - switch to heat mode.
# This makes sure the HA schedule is used instead of the SLT internal one.
- id: house_thermostat_auto_fix
alias: House Thermostat Auto Fix
description: 'Switches auto mode to heat mode. Maintains HA schedule rather than Hive schedule'
- platform: state
to: auto
condition: []
mode: single
Note: I have SLR1b and SLT3. The SLR1b has entity climate.house_thermostat_receiver.
Lovelace cards
I have a few custom cards included stack-in-card, simple-thermostat, mini-graph-card, and slider-entity-row
For basic thermostat control, on my wall tablets, I have this card:
type: custom:stack-in-card
mode: horizontal
cards:
- type: custom:stack-in-card
cards:
- type: button
entity: switch.thermostat_mode
tap_action:
action: toggle
hold_action:
action: more-info
show_name: false
show_icon: true
show_state: false
icon_height: 30px
- type: conditional
conditions:
- entity: climate.house_thermostat_receiver
state: heat
card:
type: custom:simple-thermostat
header: false
layout:
mode:
names: false
headings: false
icons: true
step: column
step_size: '0.5'
decimals: '1'
control: false
sensors: false
- align_header: right
color_thresholds:
- color: '#4B88B0'
value: 16
- color: '#e7710f'
value: 20
- color: '#FC0E34'
value: 24
decimals: 1
entities:
- sensor.house_thermostat_temperature
font_size: 75
hours_to_show: 24
show:
icon: false
type: custom:mini-graph-card
card_mod:
style: |
ha-card {
--ha-card-background: #04021C;
Which looks like this when on:
and like this when off:
To adjust the scheduling, I then have this card in a popup_card when long pressing the switch, and other dashboards I use on desktop:
type: entities
entities:
- entity: input_datetime.thermsched_01
- type: custom:slider-entity-row
entity: input_number.thermtemp_01
full_row: true
- entity: input_datetime.thermsched_02
entity: input_number.thermtemp_02
full_row: true
- entity: input_datetime.thermsched_03
entity: input_number.thermtemp_03
full_row: true
- entity: input_datetime.thermsched_04
entity: input_number.thermtemp_04
full_row: true
Which looks like this:
We find we don’t need any additional schedule changes, or different between weekday/weekend (joys of working from home!)… but extra schedule times should be simple enough to implement, and with a workday sensor, and/or additional input_datetime it should be fairly straightforward to make much more complex schedules.
Still to do:
- find a way to set temp based on current/last temperature when turning it on - as manually toggling the heating now reverts to 19C when turned on. I imagine we might never turn heating on/off, except at the end of winter - instead simply setting a lower temperature when away, for frost protection (Hive may automatically do this with its internal frost level? I need to investigate).
- lower the temperature when we leave the house/preheat when we’re coming home. to do this, I’m working on a granular home occupancy state based on our distance from home (eg going for a walk near home = only lower temp a little bit, going to visit friends for the night = lower temp completely, etc etc). Currently my basic away mode just turns the heating off - not ideal when we’re out for the day and its freezing when we arrive home…
Long post, I might have been better to start a new thread!
