Our block of flats got new solar panels and new energy meters. It’s an Eastron SDM220-MT which looks like this:
The two LEDs are encircled.
I’m looking for ways to integrate it into HA. I’ve found the Frient Electricity Meter Interface 2 LED which claims to be compatible with all meters with pulsing LEDs. The reason why I’m asking is that every meter I’ve seen used with this device has a vastly different looking single LED diode. This device uses two:
The meter provides two pulse outputs. Both pulse outputs are passive type.
Pulse output 1 is configurable. The pulse output can be set to generate pulses to represent total / import/export kWh or kVarh.
The pulse constant can be set to generate 1 pulse per: 0.001(default) /0.01/0.1/1kWh/kVarh.
Pulse width: 200/100/60ms
Pulse output 2 is non-configurable. It is fixed up with total kwh. The constant is 1000imp/kWh.
Does anyone know whether these two devices would be compatible? Thanks for any info.
