pgf
January 27, 2023, 7:31pm
1
The last thing I ever want to do with one of my heaters is turn it off completely, by accident. Bad things might happen to my house in February if I do that. There’s a reason that thermostats don’t usually have an off switch on the faceplate.
And yet there’s a small button on the HA dashboard that does exactly that. Can this button be hidden?
Hellis81
(Hellis81)
January 27, 2023, 7:47pm
2
This is not an answer to your question but you could create an automation that turns it on if it got switched off.
nickrout
(Nick Rout)
January 27, 2023, 9:34pm
3
Simple thermostat is highly configurable.
WallyR
(Wally)
January 27, 2023, 9:58pm
4
You could also make your own cards with horizontal and vertical stacks.
Mine look like this.
pgf
January 27, 2023, 10:28pm
6
Thank you all. I didn’t realize it was relatively easy to swap out the interface like that. I’ll look into it.
I also really like the suggestion to simply have an automation to turn it back on if it gets turned off. Might be easiest!
nickrout
(Nick Rout)
January 28, 2023, 12:30am
7
pgf:
Might be easiest!
But hardly intuitive. People may keep hitting the button if they really want the heater off.
WallyR
(Wally)
January 28, 2023, 12:37am
8
Put a delay in first, so it will wait 5 minutes before turning it on again.
WallyR
(Wally)
January 28, 2023, 12:39am
9
pgf:
Might be easiest!
That is without a question!
It is a simple script with a service call to turn it (and maybe a delay first to prevent a stubborn user) and then an automation to trigger the script.
pgf
January 28, 2023, 1:42am
10
Since the only user is me, I think I’ve got that part taken care of.
And if I forget, then I deserve the frustration!
nickrout
(Nick Rout)
January 28, 2023, 10:17am
11
If you are the only user, how is it a problem anyway?
Hellis81
(Hellis81)
January 28, 2023, 12:24pm
12
On a mobile device it’s easy to click when scrolling.
Since I went to the school of s happens when to you least want it to. I’d do 3 things
have a fail safe automation that runs every hour that puts the thermo in heat mode, if your house should be in heat mode
create an alert that sends you a text if the temperature falls below a threshold
create a mechanism to determine if the thermostat is really alive and sending data (integration dependent)
protect the UI control elements with the custom-restriction card
