Can I see more than "state change" event on light switch?
I am trying to see if a smart light switch can provide button depression information to create an automation (double tap-> all lights on). I am looking at a Leviton smart WiFi switch (will also investigate the Tapo version). I am brand new to HA and have nothing but the Leviton integration setup. I am in events with “*” for listing and only see state changes as shown below. I am looking for a button press not a state change. Is there any other way to see if the switch can provide that information?
When the light is on pressing on again provides nothing on the bus. I only see information when there is a state change. Is that the switch determining the current state and not rebroadcasting since it is already on?
In the data provided with the broadcast it states 32 parameters supported, is there a way to find out what those are? I can see in the mobile app numerous settings but those states are not listed in the broadcast below.
Lastly, I stopped seeing broadcasts from the switch and had to restart HA to see them again. I had cleared all events and started listening again but that did not work.
Thanks for any help.
event_type: state_changed
  entity_id: light.dimmer_1st_bedroom
  old_state:
    state: "off"
    attributes:
      supported_color_modes:
        - brightness
      color_mode: null
      brightness: null
      friendly_name: Dimmer 1st Bedroom
      supported_features: 32
    last_changed: "2024-11-16T15:09:41.582368+00:00"
    last_reported: "2024-11-16T15:09:41.582368+00:00"
    last_updated: "2024-11-16T15:09:41.582368+00:00"
    context:
      parent_id: null
      user_id: null
  new_state:
    state: "on"
    attributes:
        - brightness
      color_mode: brightness
      brightness: 255
    last_changed: "2024-11-16T15:10:11.568062+00:00"
    last_reported: "2024-11-16T15:10:11.568062+00:00"
    last_updated: "2024-11-16T15:10:11.568062+00:00"
    context:
      parent_id: null
      user_id: null
origin: LOCAL
time_fired: "2024-11-16T15:10:11.568062+00:00"
context:
  parent_id: null
  user_id: null
