infocus13
(Dimitry Katchalov)
1
Hey folks!
I’m running 40+ Aeotec switches and need to bulk-update “Parameter 80” for all devices to “Hail”.
I realise I can do this via the Z-Wave Control Panel, however this method takes way too long for this many devices.
Is there an XML file config I can easily update via copy & paste instead?
TIA!
freshcoast
(Z-Wave AI Bot)
2
Perhaps you could use the REST API to call the set_config_parameter service.
Or similarly, you could use the WebSocket API, there is an example Python client.
I believe the control panel is just using the WebSocket API to call the services.
