I have two devices. One is a switch on an ESP8266-01, and all it does is monitor a switch. When the switch closes, I want to toggle an input_boolean helper entity defined in Home Assistant.
The second device will have an automation to listen for the helper entity state to change. When it triggers, a script on device 2 will run.
So, is there a way for me to toggle the helper entity from device 1?
Ultimately, I want the switch closing on device 1 to cause device 2 to run a script.
Any help would be appreciated.
