Can i TTS Google calendar message?
Hello i installe tts and Google Calendar Event. Its possible to play on google home the message that show on google calendar component? My goal its to play every morning our 1st metting and starting time :slight_smile:
calendar.xxxxxxxxx.com off all_day: false
description:
end_time: 2016-12-29 10:30:00
friendly_name: xxxxxxxxxx
message: xxxxxxxxxx
offset_reached: false
start_time: xxxxxxx
thanks
You should be able to. Play with
{{  states.calendar.work.attributes.start_time }}
{{  states.calendar.work.attributes.message }}
Something like this:
(not tested)
tts_test:
   alias: tts testing
   sequence:
     - alias: testing the tts
       service: tts.google_say
         message: 'Your next meeting called  {{  states.calendar.work.attributes.message }} and it will be at {{  states.calendar.work.attributes.start_time }}'
Hello i try like this but did not work. google read what its inside the {{}} instead of interpret
ale_good_morning:
   alias: Alejandra Good Morning
   sequence:
     - alias: the ales tts
       entity_id: media_player.master_bedroom_home
         message: 'Good morning, Alejandra. Your next meeting called {{  states.calendar.alejandrajvrproductionscom.attributes.message }} and it will be at {{  states.calendar.alejandrajvrproductionscom.attributes.start_time }}'
you need to use data_template: instead of data:
sequence:
- service: tts.google_say
data_template:
message: ‘Good morning, Alejandra. Your next meeting called {{ states.calendar.alejandrajvrproductionscom.attributes.message }} and it will be at {{ states.calendar.alejandrajvrproductionscom.attributes.start_time }}’
but than with the right spacing :wink: to make it work
THanks :slight_smile: Work great…
I have the following script that read a calendar in the morning for me.
I would like to condition the option to read the canlendario. Only if you have an event.
How could I do it?
- id: '1529625339241'
  alias: Acordando
  - at: 00:07:00
    platform: time
  condition: []
  - data_template:
      message: 'Bom dia! Dormiu bem ?'
    entity_id: media_player.living_room_speaker
  - delay: 00:00:03
  - data_template:
      message: "A temperatura em Duque de Caxias é {{states('sensor.yweather_temperature')}}."
  - delay: 00:00:04
  - data_template:
      message: "Iniciei o preparo do seu café"
  - delay: 00:00:03
  - data_template:
      message: "Hoje é  {{  states.calendar.contacts.attributes.message }}"
  - condition: state
    entity_id: 'calendar.contacts'
    state: 'on'
  - data_template:
Whats is wrong? I have events on the calendar but Google Home doesn’t read them.
alias: Leer eventos del día
description: Automatización para leer los eventos del día desde el calendario
triggers:
  • at: “08:00:00”
    trigger: time
    actions:
  • target:
    entity_id: calendar.general
    duration:
    hours: 23
    minutes: 59
    seconds: 59
    action: calendar.get_events
    response_variable: agenda
  • data_template:
    entity_id: media_player.mini_estudio
    message: >
    {% set events = state_attr(‘calendar.general’, ‘events’) %} {% if events
    Buenos días. Hoy tienes los siguientes eventos:
    {% for event in events %}
    {% if event.start %}
    - {{ event.summary }} a las {{ as_datetime(event.start).strftime(‘%H:%M:%S’) }}.
    {% else %}
    - Evento sin hora de inicio definido.
    {% endif %}
    {% endfor %}
    {% else %}
    No tienes eventos programados.
    {% endif %}
    action: tts.google_translate_say
    mode: single
