Can I use an entity value within an entity card in a desktop.yaml file
I would like to add two sliders to enter maximum (maxValue) and minimum (minValue) in the following yaml dashboard. I found a slider card which can change the value of an entity…so I could have one slider change entity climate.lowtemp and another to create climate.hightemp but I don’t know if that will work.
Is it possible to code the max and min Value lines to use the state of the climate.xxx entity instead of a fixed value of 350 or 50? how would I code each line?
  - cards:
      - entity: sensor.maverick_temperature
        font_size: 1em
        gauge:
          animatedValue: true
          borders: false
          colorBorderInner: '#111'
          colorBorderInnerEnd: '#333'
          colorBorderMiddle: '#222'
          colorBorderMiddleEnd: '#111'
          colorBorderOuter: '#333'
          colorBorderOuterEnd: '#111'
          colorNumbers: '#ccc'
          colorPlate: ''
          colorTitle: '#f5f5f5'
          colorUnits: '#f5f5f5'
          height: 360
          highlights:
            - color: 'rgba(0, 68, 255, .75)'
              to: 100
            - color: 'rgba(4, 205, 24, .75)'
              to: 200
            - color: 'rgba(239, 93, 13, .75)'
              to: 350
          maxValue: 350
          minValue: 50
          minorTicks: 5
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Grill Temp
          type: radial-gauge
          units: °F
          valueBox: true
          valueDec: 1
          valueInt: 2
          width: 600
        type: 'custom:canvas-gauge-card'
