adamsw
February 14, 2021, 5:17pm
1
This is a automation which works but here I have fixed value of the time_pattern:
alias: 00_TMP - color change
- platform: time_pattern
seconds: '/5'
- service: light.turn_on
entity_id: light.spare
color_name: '{{ states(''input_select.light_color_5'') }}'
- service: input_select.select_next
entity_id: input_select.light_color_5
mode: single
but I would like to setup seconds interval based on below input_select:
light_color_change_time:
options:
- 2
- 3
- 5
- 10
- 20
- 30
- 60
- 120
- 300
so the automation looks like below but it doesn’t work:
seconds: '/{{ states.input_select.light_color_change_time.state }}'
mode: single
Any idea what is wrong?
tom_l
February 14, 2021, 6:49pm
2
Time pattern triggers do not support templates.
123
(Taras)
February 14, 2021, 9:02pm
3
Instead of a Time Pattern Trigger (which doesn’t support templating, like tom_I said) here is an alternative method of changing a light’s color on a periodic basis.
Create an input_boolean called input_boolean.color_changer
When the input_boolean is turned on it will trigger the automation (shown below) and start the color-changing process (the color changes according to the time specified by input_select.light_color_change_time
When turned off it will stop the color-changing process.
- platform: state
entity_id: input_boolean.color_changer
to: 'on'
- repeat:
while: "{{ is_state('input_boolean.color_changer', 'on') }}"
sequence:
color_name: "{{ states('input_select.light_color_5') }}"
- delay:
seconds: "{{ states('input_select.light_color_change_time') }}"
mode: single
adamsw
February 15, 2021, 3:23pm
4
@123 Thank you for the example, I made a small adjustments and it works as expected. Thank you
- platform: state
to: 'on'
- repeat:
while:
- condition: template
value_template: '{{ is_state(''input_boolean.color_change'', ''on'') }}'
sequence:
- delay: '{{ states(''input_select.light_color_change_time'') }}'
mode: single
