Can i use network drives for storage?
I have HAOS_OVA-9.4 running in kvm. Is it possible to add network drives to this installation to store camera pictures and videos ?
Thanks in advance
You might be able to do it using Samba share
The shared folder are on an ubuntu. But dont know how to use them inside home assistant
this could get you started…
I have been trying this but this is the error i am getting
Logger: homeassistant.components.shell_command
Source: /usr/src/homeassistant/homeassistant/components/shell_command/__init__.py:115
Integration: Shell Command ([documentation](https://www.home-assistant.io/integrations/shell_command), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+shell_command%22))
First occurred: 1:36:31 AM (1 occurrences)
Last logged: 1:36:31 AM
Error running command: `mkdir -p /media/Pictures;mount -t cifs -o vers=3.0,noserverinfo,username=***,password=***,domain=WORKGROUP //192.168.50.51/300/Pictures /media/Pictures`, return code: 255
NoneType: None
And this is the error when i look at the terminal
