Can I use TRADFRI groups when using Discovery + the reworked IKEA TRADFRI integration in v0.101.0
I’ve just updated to v0.101.0, and so far so good, nothing seems to be broken.
I’d like to import my TRADFRI groups if possible, in the docs here:
it says you can use the config file to set this option:
allow_tradfri_groups (boolean)(Optional)
However I am already using the discovery: feature, so have no tradfri settings in my config file, is it still possible to somehow import the TRADFRI groups while using discovery?
If you need support on Beta HA version, you need to visit the Discord channel.
v0.101.0 is the latest stable current release, I’m not running the beta release.
Hahaha. My browser still showed 0.100.3. Had to hard refresh it 3 times to get it to change. My bad!
No problem, it was only released a few hours ago. :slight_smile:
I even triple checked I hadn’t missed it before I commented. Bloody Cache.
I am a beginner with HA but have the exact same question and situation. Is this possible ?
I solved this for myself by
  • deleting trådfri integration from the UI
  • Adding the below manually (replace your IP)
tradfri:
  host: 192.168.1.20
  allow_tradfri_groups: true
  • Go back into integrations, press “configure” on the IKEA trådfri integration
  • Add security key
and BAM. I can now control my rooms / groups from Homeassistant so they actually transition simultaneously! :smile:
