I’m wondering if it is possible to use two TM1637 7-segment displays with ESPHome? Is it similar with I2C where I would create a separate bus, but for SPI? I will be using it with ESP32 and one would show temperature and the other humidity, if it’s not possible can I flip between those two sensor readings on one 7-segment display, similar to pages?
Thanks.
Have you seen the MAX7219 7-Segment Display — ESPHome
If the layout of two displays next to each other doesn’t suit you, I think you can desolder them and place them how you want with wires.
