Can I useSonoff SNZB-02 Temp Sensor as thermostat with scenario?
Is it possible to use Sonoff SNZB-02 Temp Sensor as thermostat with scenarios?
lets say if Sonoff SNZB-02 Temp Sensor temp is under 19c set A/C to on if it is above 21 set A/C to off.
If you can control the on and off of the A/C and read the sensor in HA, then there really is very few limits of what is possible.
Sonoff is well supported with official addon from Sonoff itself.
It is a Zigbee sensor, can be used with any Zigbee integration. To control your A/C, you probably still need something more (smartplug, ir blaster, … depending on your A/C)
yes i have an ir blaster i tried to set a scenario if temp sensor is bellow 19c then turn on the ac via ir blaster and it works :slight_smile:
