Can I write an automation to reload/restart an integration?
The key is service: homeassistant.reload_config_entry
@Snille
Would not recommend this one for Tractive, as this generated a lot of API calls and I have ended up limited by them, had to pause everything for at least a week, nevertheless you might be able to use this for other purposes or just to have an idea.
Basically checking for feature unavailability, with conditions like having network communication with router and DNS and my router was not restarted manually, then checking for HA restart with input booleans (those are updated at the time of HA shutdown or Startup)
Below is the automation from where I call a script:
alias: Auto-recover Tractive integration
description: ""
  - platform: state
    entity_id:
      - switch.maya_live_tracking
    to: unavailable
    for:
      hours: 0
      minutes: 3
      seconds: 0
  - platform: state
    entity_id:
    to: unknown
    for:
      hours: 0
      minutes: 3
      seconds: 0
  - platform: state
    entity_id:
      - switch.maya_tracker_led
    to: unavailable
    for:
      hours: 0
      minutes: 3
      seconds: 0
  - platform: state
    entity_id:
    to: unknown
    for:
      hours: 0
      minutes: 3
      seconds: 0
condition:
  - condition: state
    entity_id: binary_sensor.192_168_69_1
    state: "on"
    for:
      hours: 0
      minutes: 5
      seconds: 0
  - condition: state
    entity_id: binary_sensor.1_1_1_1
    for:
      hours: 0
      minutes: 5
      seconds: 0
    state: "on"
    enabled: true
  - condition: state
    entity_id: script.router_restart
    state: "off"
    for:
      hours: 0
      minutes: 5
      seconds: 0
    enabled: true
  - condition: state
    entity_id: input_boolean.ha_start
    state: "off"
    for:
      hours: 0
      minutes: 10
      seconds: 0
  - condition: state
    entity_id: input_boolean.ha_stop
    state: "off"
    for:
      hours: 0
      minutes: 10
      seconds: 0
  - parallel:
      - service: script.fix_tractive_integration
        data: {}
      - service: notify.mobile_app_xel_s23
        metadata: {}
          message: Tractive integration reloaded
          title: HA debug message
  - delay:
      hours: 0
      minutes: 5
      seconds: 0
      milliseconds: 0
mode: single
And below the script being called, this device “xa3cs9fbf047b5b03f995867985709f6” is my Tractive tracker device id (changed some numbers in it before sharing to avoid funny business). The “activitylogger” part can be skipped, this is just a way for me to log activities and events on one of my dashboards.
alias: Fix Tractive integration
sequence:
  - parallel:
      - service: input_button.press
        data: {}
          entity_id: input_button.activitylogger
      - service: homeassistant.reload_config_entry
        data: {}
          device_id: xa3cs9fbf047b5b03f995867985709f6
        enabled: true
mode: single
icon: mdi:dog
I’m sure there are bettery ways to do this, but this is what I’ve come up with for my needs. I’m using the same logic to handle some of my other integrations which occasionally need restart, like Sonoff or Xiaomi Miot Auto and helps a lot to avoid manual effort.
Really appreciate you posting the YAML here. My Nexia integration for my new American Standard HVAC keeps dropping and needed a way to restart it. I was able to use the code here to hack something together.
alias: Reload Nexia when Unavailable
description: ""
  - platform: state
    entity_id: sensor.system_####_humidity
    to: unavailable
condition: []
    metadata: {}
    data: {}
      device_id:
mode: single
One of my integrations needs reloading every couple of days.
The following did not work:
Though maybe I messed something up (though I used the correct IP and integration ID), from here, this placed in configuration.yaml also did not work:
rest_command:
reload_myintegration:
url: http://[IP]:8123/api/config/config_entries/entry/[Config Entry]/reload
method: POST
headers:
authorization: 'Bearer [Long-Lived Access Token]’
content-type: ‘application/json’
But this worked: Create a token by clicking your name, Security tab, scrolling down to Long-lived access tokens and clicking create token. Insert that token in the code below [token]. Place the code in configuration.yaml and restart HA. You can rename “myintegration_restart” to the name of your integration(s).
shell_command:
myintegration_restart: “/usr/bin/curl -X ‘POST’ -H ‘authorization: Bearer [token]’ http://localhost:8123/api/config/config_entries/entry/[integration id]/reload”
Then in your automation:
actions:
  • data: {}
    action: shell_command.myintegration_restart
    enabled: true
Thank you! my Sonoff TRV link with Better Thermostat (with z2m) was not responding when bThermostat switched to heating. I found that when i reloaded the specific climate Better Thermostat entity that it worked. So this helped me create a automation to reload the better thermostat each time it switches to heating.
I get this when I try the script that BigTerrick mentioned:
Message malformed: extra keys not allowed @ data[‘trigger’]
Disregard - I found my mistake
I was trying to apply this as a Script, when I should be applying as an Automation.
I use this and it works great:
alias: Restart myJdownloader every 2h
description: ""
triggers:
  - trigger: time_pattern
    hours: "2"
conditions: []
actions:
  - parallel:
      - action: hassio.addon_stdin
          addon: myjdownloader
          input: restore-sensor
        enabled: false
      - action: homeassistant.reload_config_entry
          entity_id:
            - sensor.jdownloader_nas_status
          device_id:
            - 3ac1f5109e3d47fb599f533317e0120f
            - 72bf4e9e01a21046cddb5fb08500ff43
          entry_id: 01JZEW39B0YCXN19YAPNFT1NFW
mode: single
