For example, Can I have one HA with Z-Wave Controller and configuration?
The second HA device that does MQTT with all devices that use MQTT?
And another HA that does everything else?
I want it all work together, so I can do something like this: If some MQTT device send a signal I want to be able to turn on/off Z-Wave device.
Look for MQTT event stream on this forum - I’m not using i, but I’ve seen a number of posts on this here.
There used to be a master/slave functionality that does not exist any more, but looking for that term might give you some results as well.
Yeah, it’s straightforward - we can use HA’s built in Rest API to get them talking to each other.
Here’s the HA link for how it’s done:
And some examples of how to do it, in these cases it uses a Pi with Hassbian to do Bluetooth scanning, and the main Pi HA install reads from that to bring it all together onto to the one HA page.
I run two Pi Zero doing extra little tasks for me and bring them together on my main Pi 3. Plus it means I can extend my Bluetooth scanning out to the range of my wifi
It’s not an extra hassle, the sensor entries are just a tiny bit longer.
Actually, I am thinking about two devices. I want to install HA on the Virtual Machine on my Hyper-V server. The problem is that I cannot use Z-Wave USB Stick with Hyper-V. Hyper-V does not allow USB path through devices, so I wonder if I can have Z-Wave controller on another RPi.
There are certainly others that have gone this route, having the zwave gear on a separate server. Some use Vera (which I personally don’t like after fighting with it for years before throwing it out) but I think there are examples of using a RPi as well
