I was just making some progress with HASS and have clearly broken something.
It’s running on my Pi but I cant connect to it. I have static IP set so I’m looking in the right place and can access the config folder using Samba.
The log shows this:
2018-07-25 19:01:47 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-07-25 19:02:00 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=16 from 2018-07-25 18:50:51.267122)
2018-07-25 19:02:12 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2018-07-25 19:02:16 ERROR (SyncWorker_1) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-07-25 19:02:21 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-25 19:02:38 ERROR (SyncWorker_12) [homeassistant.components.notify.ios] The notify.ios platform was loaded but no devices exist! Please check the documentation at https://home-assistant.io/ecosystem/ios/notifications/ for more information
Does any of this give any clue as to why? Do I need to rebuild from scratch?
Any help appreciated.
