Can no longer connect via http://homeassistant.local:8123/ - have to use IP address
Hey, I’m new here, and also very new to HA, so apologies if this is a stupid question.
Yesterday I set up HA without any issues, but this morning I’m unable to connect via http://homeassistant.local:8123/ - I can connect via the IP address, but I’m curious as to what I’m missing here?
I never could get it to work. Actually, I never bothered to figure out how it’s supposed to work in the first place.
But now I’m curious, so I’ll give this post a bump…
What’s your network domain name? In home assistant, what’s the hostname?
When you figure out those 2 item, connecting will be
http://hostname.domain:8123
Edit: and before you ask, your domain name is set up by your router. So only you and your router know that info
Edit 2: And lastly, if your domain name is still local, something is wrong with your dns server inside your router.
I believe .local is simply the default domain used by a router running the Multicast DNS protocol. I have also seen that some web browsers will do it automatically while others don’t.
As others have said it’s a dns issue on your system, not a HA issue as such. You can add homeassistant.local to the hosts file on the computer if it really bothers you.
If you are on a windows machine you can use the "nslookup " command to see what your local dns resolver resturns as the known fqdn.
I yesterday also got the same issue.
If you enter the url http://homeassistant.local:8123/
then make sure that under “settings” → “network” the hostname is the same.
If you enter the url http://homeassistant .local:8123/
Thank you so much, I couldn’t find anything in the official docs or other forums regarding this and it was driving me crazy. I forgot I changed the hostname to something like foobar-family-homeassistant and that would affect the url.
