Greetings,
is it possible to trigger from inside the nodered addon to start another addon in HASS/supervisor?
nodered has access to home assistant services doesn’t it? There is a service for starting an addon.
I would also be interested in that since some time deconz addon does not auto restart if the host reboots (although so configured)
Yeah will go deep in to this, when im free.
I underatand that there is an API as was mensioned. And i guess some long time token and send APIs
Then you need to debug why that happens. Starting the addon by some other mechanism is only a workaround. A perfectly doable work around which you now have the answer to.
Why would you need to muck around with a token and the api when you can just call the service from node red or from ha?
Hmmmm interesting,will report back :> <3
