Can not add lupusec alarm system
Hi there! New to Home Assistant :slight_smile:
I wanted to add my lupusec alarm system https://www.home-assistant.io/integrations/lupusec/
it can’t be found in the integrations.
when i add the lupusec section to my configuration.yaml i get
Invalid config
The following integrations and platforms could not be set up:
* [lupusec](https://www.home-assistant.io/integrations/lupusec)
Please check your config.
what am i doing wrong?
Same issue, I use the lupus xt1 plus
Hi, I’ve integrated my LUPUSEC XT1 without great problems, following the mentioned “Integration page” of Home Assistant.
  • I control the Alarm state
  • I send different notifications to my phone about the XT1-State
  • If Alarm is detected Lamp will start flashing
  • newest I control my Climate/Heating by state of window-sensor
    I’m not sure if other LUPUSEC types instead XT1 are also working! Which type of Alarm System do you have?
Did you fix this?
If so, how?
I have the very same issue.
Thank you in advance.
