Can not add Piper
I was able to use piper as docker container all the time without any problems. Yesterday came a Docker update for Piper.
When I removed the Piper integration from Home assistant and wanted to add it again, I now get constantly: Unknown error occurred
This is what the log says when I try to add piper:
Logger: aiohttp.server
Source: components/wyoming/data.py:69
First occurred: 09:43:27 (1 occurrences)
Last logged: 09:43:27
Error handling request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 181, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 297, in async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 393, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/wyoming/config_flow.py", line 41, in async_step_user
    service = await WyomingService.create(
  File "/usr/src/homeassistant/homeassistant/components/wyoming/data.py", line 37, in create
    info = await load_wyoming_info(host, port)
  File "/usr/src/homeassistant/homeassistant/components/wyoming/data.py", line 69, in load_wyoming_info
    wyoming_info = Info.from_event(event)
  File "/usr/local/lib/python3.11/site-packages/wyoming/info.py", line 95, in from_event
    tts=[TtsProgram.from_dict(d) for d in event.data.get("tts", [])],
  File "/usr/local/lib/python3.11/site-packages/wyoming/info.py", line 95, in <listcomp>
  File "/usr/local/lib/python3.11/site-packages/wyoming/util/dataclasses_json.py", line 17, in from_dict
    field = cls_fields[key]
KeyError: 'description'
Does anyone know what is causing the problem?
I have the same issue
Sorry, I’ve restored the old version for now. The new version will only work with HA dev.
Thanks for the quick help. Now its working.
With the latest version of the rhasspy/wyoming-piper image, I can’t get it to start properly. I posted about it here:
Never mind. Seems to have corrected itself!
Maybe unrelated but i was attempting to use piper/whisper for the new voice assistant speaker that just came out and was running into these similar errors but after parsing I found it was my pi-hole dns blocking the huggingface.co from resolving on my network.
I don’t run anything crazy beyond the defaults but adding a whitelist for huggingface.co, syncing pi’s, flushingdns and making sure the website could resolve got it up and running. might help someone else. <3
