I have 3 Xiaomi Bedside Lamp wirh esphome firmware. I change some values in the YML and now I can not connect from ESPHome dashboard.
From Home Assitsant all is OK.
This is the error message:
INFO ESPHome 2024.3.1
INFO Reading configuration /config/bedside-lamp-xxx.yaml...
INFO Starting log output from 172.16.8.72 using esphome API
INFO Successfully connected to bedside-lamp-xxx @ 172.16.8.xx in 0.057s
WARNING bedside-lamp-xxx @ 172.16.8.72: Connection error occurred: bedside-lamp-xx @ 172.16.8.xx: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (ESPHome Logs 2024.3.1).
WARNING Can't connect to ESPHome API for bedside-lamp-xxx @ 172.16.8.xx: bedside-lamp-xxx @ 172.16.8.xx: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (ESPHome Logs 2024.3.1). (HandshakeAPIError)
INFO Trying to connect to bedside-lamp-xxx @ 172.16.8.xx in the background
This is the YML:
esphome:
friendly_name: bedside-lamp-xxx
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Bedside-Lamp-xxx"
password: "xxxxxxxxxxx"
captive_portal:
How could I get connection from Esphome dashboard to upgrade or see the logs?
Kind regards.
