Can not connect the App when using Docker but works when using pip install
I’m trying to connect my Home assistant to the App.
When using the pip install method I can connect.
When using docker I get the following Error in the logfile:
2020-01-28 14:53:43 ERROR (MainThread) [homeassistant.components.auth.indieauth] Timeout while looking up redirect_uri https://home-assistant.io/android
2020-01-28 14:53:43 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.2.104
The App says: "Invalid client id or redirect uri
My config.yaml looks pretty much the same on both instances:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
 - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
tplink:
websocket_api:
mobile_app:
discovery:
The docker-compose.yml is:
version: '3'
services:
  homeassistant:
    container_name: home-assistant
    image: homeassistant/home-assistant:stable
    restart: always
    volumes:
      - ./homeassistant:/config
    environment:
      - TZ=Europe/Berlin
    network_mode: host
  nodered:
    container_name: node-red-hass
    image: nodered/node-red
    restart: always
    ports:
      - 1880:1880
      - 9229:9229
    environment:
      - TZ=Europe/Berlin
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - ./nodered:/data
    network_mode: host
  rhasspy:
    container_name: rhasspy-hass
    image: "synesthesiam/rhasspy-server:latest"
    restart: unless-stopped
    volumes:
        - ./rhasspy/profiles:/profiles"
    ports:
        - "12101:12101"
    devices:
        - "/dev/snd:/dev/snd"
    command: --user-profiles /profiles --profile de
    network_mode: host
  marytts:
    container_name: marytts-hass
    image: synesthesiam/marytts:5.2
    ports:
      - "59125:59125"
    network_mode: host
Have you thought about trying this?
Thanks for your answer.
I have tied what you suggested:
http:
  base_url: http://192.168.2.145:8123
It did not help.
I still get the error.
BTW: The Ariela App works fine. With and without the above settings.
Can your host resolve DNS?
By the way, in your compose file, passing ports and network_mode is redundant. Pick one or the other. Home Assistant needs network_mode, but the others may not.
Make sure your IP is not in the ip_bans yaml also.
What do you mean with: “Can your host resolve DNS”?
I’m writing this from my host that runs docker. So there should be a valid DNS resolve mechanism avtive.
Or do you mean that my host should be a DNS server?
Or shall I check whether my Docker container can resolve DNS?
For now I only want to test it locally without external access.
BTW: When using the scan button in the App it does not find my Home Assistance instance. I have to enter the IP manually.
I have no ip_bans.yaml file yet.
I was asking if your docker host could resolve DNS. If you are using it to browse the internet and post here, then that question is answered.
This is a known problem. It hasn’t worked since the app was released AFAIK.
Then the answer is yes.
Is there any way to debug this?
Can I obtain more informative log messages from my Home Assistant and from the Phone?
