I am a newbie with Home Assistant. I just discovered it and already lovin it!
I installed the Hass.io Access Point on a Raspberry 4 and would like to use it in “bridge mode” like I did with RaspAp before. I can setup the WiFi and it is available, but when I try to connect my iPhone it couldn’t get an IP address. As soon as I activate the DHCP it works.
What I am doing wrong. I tought deactiveate the DHCP the DHCP server inside my network is used to get the IPs for the connected Accesspoint devices. I am using a FritzBox 4970 and eBlocker as DHCP server.
Any Idea would be helpful. Thank you
Kind regards
D-Rock
