Can not found log and history
Could you help me to display log and history in the panel?
the log is as following.
2018-07-29 10:34:28 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) file is encrypted or is not a database (Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2018-07-29 10:34:55 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Component failed to initialize.
2018-07-29 10:34:55 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history. Setup failed for dependencies: recorder
If your database file is corrupted, you can delete it. The location depends on your installation, but on hassbian it is at /home/homeassistant/.homeassistant/home-assistant_v2.db
